Johnboy98 0 Posted November 6, 2005 Just a quickie does a 94 VR6 have an oil pressure sender fitted as standard ?my assumption is no but would like to double check before I order as im gonna fit these little beauties off FleaBay! Quote Share this post Link to post Share on other sites
RW1 0 Posted November 7, 2005 No. You have to fit either banjo coupling or tee it with the pressure switch or use a dual sender directly screwed in the cylinder head switch position (ie. includes the switch, usually the cylinder head logic 0.3bar ). There are two oil switches, one works in reverse logic for loss of pressure on the main bearings. Looking at the gauge, you need a 5 bar sender to match the gauge. If you use the 10bar version it will scale wrong. The gauge will saturate at 5 bar for the first 5 minutes as the oil pressure will be 6 - 6.5bar with cold oil. . Quote Share this post Link to post Share on other sites
Johnboy98 0 Posted November 7, 2005 Great info there RW1, sounds like you know yeh Bars, banjo's and bearings. Nice plate by the way. Quote Share this post Link to post Share on other sites
