ShockVR6
Electrical Water Pump (VR6) location ?
Can someone plz tell me where the water pump is on a vr, as i have a water leak and im trying to figure out where its coming from.
ThnX in Advance
if you take off the cubbins around the engine casing you will see it to the right og the block under there.
It has an outlet with a pipe stuck on it. Make sure the pipe is on properly as the oulet can corrode and start pushing the pipe off the outlet.
Listen to the pump and make sure its working.
Try that first mate, thats what was up with my CVR.
