G60-R
Rear washer
When i try to put my rear screen washer on it makes noise under the bonnet like it should be working but nowt comes out. Any ideas?
Its most likely blocked. My rear wash used to work, but its now progressed to more of a dribble. Haven't found a way to unblock.
As Supercharged says. you can also try blowing out crud from the pipes by taking them off, but they arre often brittle and easier to replace the lot for a small price. Assume the fronts work fine?
yeah, front all good.
cheers, i'll add that to my 'list of things to do on car' it seams to growing fast!
I had the same problem with mine about a month ago. The problem for me was the plastic pipe that goes through the bottom of the wiper arm had broken off. Then i found a disconected water pipe if the that helps any??????
