g60bv
water injection probs
when my water injection kicks in it keeps blowing the in line fuse. its a aquamist system, about 2 years old 4k use. always use the correct methonol. any one else had problems.?
yeah did that. it was blowing 7.5 's so i put in a 10. and i only had a 20 left. that seems to be working. but at what expense. it could be putting more pressure on the pump if it is damaged,.?
They list 20amp peak current draw anyway, mine runs a 20a fues. Maybe the colder temps are putting a little more strain on the pump?
It sould be a race pump, the failure prone jobbies all had red anodised heastsinks iirc, very easy to strip the pump, there`s a writeup on the aquamist forum.
