B DUB 0 Posted November 13, 2005 ANY BODY HELP :? MY CORRADO STUTERS IN 3RD GEAR AND FINALLY IN 5TH WHEN GOING UP THROUGH THE GEARS .( ITS AS IF THE ENGINE CUTS OUT AND THEN STARTS AND JUMPS LIKE WHEN UR BUMP STARTING IT) IF THAT MEANS ANY SENSE TO U.. :cry: Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 13, 2005 vacum leak, spark plug, ht leads, fuel pump, dizzy cap, rotor arm. all worth checking and replacing first. might also be a blocked injector? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 13, 2005 WHAT ENGINE U GOT B DUB? Might help for the diagnosis .. ;) Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 14, 2005 i think he mayhave a g60 is this the glitter car?? Quote Share this post Link to post Share on other sites
B DUB 0 Posted November 14, 2005 ITS A CORRADO G60 STAGE 4 SUPERCHARGER WITH CHIPED ECU BY JABBASPORT.(yes it is the glitter car) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 14, 2005 Oh, I see what you mean by Glitter car now... I just thought it was badly stone-chipped in the pic! (sorry.. :oops: ) Quote Share this post Link to post Share on other sites
bix 0 Posted November 14, 2005 (yes it is the glitter car) w00t you found the caps key :) Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted November 14, 2005 Definitley sounds like an ignition fault, can you see any blue sparks when it is idling, (and obviously helps if it is night time) because that's the prob I had on my VR, new plugs and leads, job done... Quote Share this post Link to post Share on other sites
B DUB 0 Posted November 14, 2005 I will change them and try it out . cheers mate Quote Share this post Link to post Share on other sites
mistrall 0 Posted November 18, 2005 :shock: - gliter 8) SUPERB!!! Quote Share this post Link to post Share on other sites
