vwcorrado
Got me baffled!
:x Hi there can anybody help. I bought an imported vr6 which was idling a bit irratic. but all the power was there. last couple of weeks there is no power on acceleration. changed,plugs, leads, coil, checked dibi cap cap for cracks. i can start it and rev the wottsits out of it but as soon as you drive it the power is not there. ? ? ? ? ? any help greatfully recieved.
It would help if you defined "no power" a bit better. It could be cam sensor, but you'd only lose a portion of power output, so it'd just feel a bit flat. It wouldn't be a 1.1 though, so "slow" is subjective ...
Does it smoke? Use oil? Does it stutter or just pull smoothly through the revs but without real shove? What MPG are you getting?
VAG-COM/VW diags kit will help you just by telling you if all your engine sensors work as they should..
Eh? Fit a new one without knowing??
Plus if it is the camshaft sensor, the fault needs to be cleared before the engine will run properly again.
Diagnose first. Analyse the result. Then apply corrective action!. :)
