gofaster_rado 0 Posted November 16, 2005 I have a 1991 corrado g60 with a Lysholm charger fitted, I have replaced coil, dizzy cap, rotor, plugs and leads. The car will start first turn of the key but when I try to drive it hesitates and splutters also I noticed that the catalytic converter is glowing red and is heating up the gear lever mechanism and that there seems to be exhaust gases coming up behind the inlet plenum any ideas would be greatly appreciated Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted November 16, 2005 if its glowing then i wouldnt drive it mate,could be running way to rich,might be worth giving gworks a call in case you cause major melt down Quote Share this post Link to post Share on other sites
gofaster_rado 0 Posted November 16, 2005 Can't drive it, as soon as you try to take off it just hesitates and shudders Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 16, 2005 timing out? Quote Share this post Link to post Share on other sites
gofaster_rado 0 Posted November 16, 2005 Timing set to 8 degrees btdc Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted November 16, 2005 where are you based mate? Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted November 16, 2005 has the cam belt been changed recent? Quote Share this post Link to post Share on other sites
gofaster_rado 0 Posted November 17, 2005 Cam belt was changed about a month ago Quote Share this post Link to post Share on other sites
2cc 0 Posted November 17, 2005 Well I'm no expert but sounds very similar to saysomestuff's problem a while back (have you got that fixed yet mate?) so I'd suggest you check the lambda probe hasn't died as that will cause the symptoms you describe. Plenty other things it could be, but it's something worth looking at. Quote Share this post Link to post Share on other sites
gofaster_rado 0 Posted November 18, 2005 Would disconnecting the lambda probe give any indication or can I test it on the car ??? Quote Share this post Link to post Share on other sites
2cc 0 Posted November 18, 2005 you test it on the car, have a look here http://www.lambdasensor.com/main/mtesting.htm Quote Share this post Link to post Share on other sites
