KipVR
CENTRAL LOCKING JAMMED!
Can anyone advise me what to do in this situation:- The cental locking seems to have packed up on my passenger side door. I can see the door pin rising but then it sinks down again and it won't let me pull it back up to release the lock (I havent tried excessive force)! This means I can't get the door card off to get at the vaccum hose which I presume is leaking somewhere.....
I would have thought that taking the multiplug out of the central locking unit in the boot (rhs behind the panel) might disable the central locking to a point. Then try getting the door to unlock with either the interior handle/pin or key from the outside.
Ahh, having looked at others on this website I discovered it was the door lock mechanism stuck half way, seems to be quite common! 1 tent peg stuck down in between the seals with the window down did the trick!! Took the whole of the central locking system in the boot apart first though, doh!!!!
