matthewb1985
knock sensor , spark plugs
my car is pinking quite badly had new lambda sensor and temp sender so i have just removed spark plugs to see if they are the right ones. they are champion ones grade 8. is this ok for a 2.0 16v? also where are the knock sensors on ther 16v anybody have any pics??
cheers
9A 2.0 valvers have just 1 knock sensor,like a G60 mill,it's located near the engine block's breather,should have a black 3 pin socket but could also be blue coloured.
If your adament the timing has been set correctly then it may be worthwhile getting your fuel pressure tested as the pump may be slowly failing not supplying enough fuel to the rail, hence the pinking.
