Dubsingh
vr6 syncro
Hi all
I have a vr6 in my rallye. but recently have had a right mare with it. the take off drive standard from the standard 02c gave up the ghost along with the damaged dougnut. i had a right dilema trying to source a new drive. so my question is what 4 wheel drive gear box will be compatible with the vr6 block?
i was thinking about the mk4 golf 4 motion set up...
1) will it fit
2) will i need a matching rear diff or can i keep the standard rallye diff
3) any one got a 2.9 vr lump for sale (ABV code)
:mad: :? :?:
the transfer box is matched to the rear diff.
if your car is the one I'm thinking it is (blue RHD one with corrado dash?) then it actually has a rallye gearbox, transfer box and rear diff, with a vr6 syncro bellhousing.
VR6 syncro and rallye diffs are not the same, neither are the transfer boxes.
how about you buy an 02m 6 speed, prop and haldex diff off me! not a direct fit by any means, but it will bolt up to your engine ok, and if you know a man who can shorten driveshafts and props and fabrocate a diff mount then you'll be sorted (well, apart from the diff controller but that's another subject in itself)
