sharlie1982
Exhaust Knocking
When I bought my 1992 C G60 back in may, it had a stupid Rage exhaust system fitted with a Cat replacement pipe.
This was so loud it was embarrasing. I sounded like a Chav with a PECO big bore on his/her Nova 1.0. :roll:
I purchased a Magnex cat back system which is very nice to look at and sounds great. :)
The only problem is that it keeps on blowing where it meets up with the cat replacement pipe. I have to keep on re-tightening the u clamps every week, and it is just becoming annoying. :roll:
Also because the cat pipe is slightly kinked in its design, the rest of the system does not run down the center of the exhaust tunnel. Thus causing the clamps to hit the underside under mid to hard acceleration. :mad:
Anyone else have the same problems???
Yeah, I've got a Milltek and it was getting thru 3 exhaust rubbers in as many months - now using poly ones so hopefully will hold it a bit more steady...
It maybe easier for you just to get a new cat bypass pipe tho for the sake of £50-£70
