KADVR6 0 Posted December 5, 2005 i do hope its not though. over the last 2 days when i change from 1st to 2nd, and 2nd to 3rd. its feels like i have just gone down a pot hole, the whole car jerks?? i have new engine mounts on the car. and nothing appears to be loose, also it doesnt always happen only about 50% of the time, any ideas?? :( Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 5, 2005 Did you change the transmission mount also?? - I suspect that may have gone with the other mounts being replaced for newer stiffer ones... Quote Share this post Link to post Share on other sites
KADVR6 0 Posted December 5, 2005 yeh i replaced all of them at the same time, :( really dont need expense at the moment Quote Share this post Link to post Share on other sites
buttles 0 Posted December 5, 2005 Engine missing? And before any smart a*&^ says, I mean a missfire :) Mine had a habit of doing it every now and then. Ignition usually the culprit. Coil pack had a crack in it. Bit of J B weld seems to have done the trick. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 6, 2005 You mean it only does it when you operate the clutch? Or it only does it when you come off the throttle? Or it does it when you get ON the throttle? More details please! Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 6, 2005 could be a broken spring in your pressure plate Quote Share this post Link to post Share on other sites
KADVR6 0 Posted December 6, 2005 this only happens when im changing gear, all the rest of the time its fine, ive checked the clutch and its not slipping, really confused :( Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 6, 2005 But at what part of the "changing gear" sequence of events does it happen? Changing gear is (not necessarily in order): - off throttle - dip clutch - select new gear - lift clutch - back onto the throttle There's five points here where you might get a jolt, and they could each be for different reasons.. Quote Share this post Link to post Share on other sites
KADVR6 0 Posted December 6, 2005 sorry, this always seems to happen when i am lifting off the clutch after i have selected the next gear :( Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 6, 2005 If it feels snatchy when you let the clutch out it could well be the pressure plate. No offence but are you sure you fitted the new mountings correctly? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 6, 2005 Yeah, first things first, do the engine movement test with the brakes on and the bonnet open. Lift the clutch gently in gear and see how far it moves... Quote Share this post Link to post Share on other sites
KADVR6 0 Posted December 6, 2005 thanks so far with the help guys, midland vw did the mounts for me. and the engine hardly moves at all so its not that, a work mate said it could be a flat spot? how can you tell as it revs fine when parked up. :( Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 7, 2005 A flat spot ...?! when you're not pressing the throttle?? I'd concentrate on the clutch. It will have had to be removed to get to the timing chains, so as someone else said, that's probably where the issues are. Did you put the crank sensor wheel back in tightly? It's possible (I believe) to get those in the wrong place or make them loose so that the ECU has trouble and shuts the engine down for a revolution or two .. Quote Share this post Link to post Share on other sites
