markievw 0 Posted December 10, 2005 hi A problem has started when i try and turn the key, was wondering if anyone else has this problem I filled up with petrol yesterday and came to turn the key and it wouldnt turn in the barrel!! I tried it for 5 mins and still no luck. Put a bit of 3 in 1 oil and still no luck. So left it and came back after 10 mins and key turned first time! Any ideas? How much are you looking for a new ignition barrel? if that is what it is. and do have to change the key or can you buy the set to do both doors and ignition barrel. thanks in advance of your replies mark Quote Share this post Link to post Share on other sites
Trig 0 Posted December 10, 2005 Try a search mate, it's been covered a lot before as it is a commmon problem. Take a look at this thread, long discussion on how to replace the switch etc. http://www.the-corrado.net/.archive/forum/viewtopic.php?t=4495 You could also go for a 'push button' start, guide to install of that here.:) Quote Share this post Link to post Share on other sites
Trig 0 Posted December 10, 2005 Oh and there is this Corrado Forum wiki article:- http://www.the-corrado.net/wiki/index.p ... ion_barrel :) Hope that helps Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 10, 2005 Easy now - before you get carried away! Sometimes when you park up, the steering lock will catch on the ignition barrel and stop the key from turning. Just give the steering wheel a little wiggle and the key will turn :) However, if you can turn the key and the car doesn't start - then look at replacing the ignition switch. Quote Share this post Link to post Share on other sites
Trig 0 Posted December 10, 2005 Valid point dinkus, forgot about that little issue. If the key isn't turning after that then it's more likely to be the barrel rather than the switch though isn't it? Quote Share this post Link to post Share on other sites
selbekk 0 Posted December 10, 2005 I hate that steering lock thing. Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 10, 2005 Yeah, if the thing has completely ceased, then you'll need a new barrel. But because he came back to the car a bit later and it worked first time, it sounds like it was probably just the steering lock. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 10, 2005 Ok, sometimes the screw holding the barrel becomes loose - take the lower cowling off and have a look - be careful when tightening tho as the metal is quite soft... Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted December 10, 2005 my steering lock doesnt even engage - sounds like thats a good thing considering how many people have this problem :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 10, 2005 my steering lock doesnt even engage Probably broken if the car was stolen at some point? Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted December 10, 2005 Yeah thought that but the HPI is clear - had to check since its had 3 different reg no's throughout its life Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 10, 2005 Yeah - and if it doesn't turn then wiggle it about a bit and make sure the lock barrel is all the way out... Quote Share this post Link to post Share on other sites
