Vr6_polo 0 Posted December 13, 2005 Hi peeps i was hopein you could help me figure a little problem out ive got a 2.9 Vr6 ABV in my 6n polo problem is it runs fine and goes like stink for about the first 5mins of running the engine but as soon as it warms up it gives a little splutter (flat spot) when u press the throttle and seems to lack power but revs right through just nowhere near as quick as normal from what ive read i was going to change the HALL SENSOR but as its a Dizzy engine VW want 190+VAT for another dizzy does anyone know where i can get just the sender or do i have to get the whole dizzy :( :cry: Quote Share this post Link to post Share on other sites
VR6 0 Posted December 13, 2005 Have you had it on VAG com? Cam position sensor and throttle position sensors are culprits of poor running. Have you changed leads and plugs recently? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 13, 2005 Could just be getting monumentally hot, sitting in a 96n polo engine bay, and pinking to death.. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 13, 2005 Could just be getting monumentally hot, sitting in a 96n polo engine bay, and pinking to death.. Yeah - I know they fit in there as Stealth did one once... then swore never to do another, lol! Vr6_polo, change the blue temp sensor first then have a look on VAGCOM Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 13, 2005 Cam position sensor and throttle position sensors are culprits of poor running. Have you changed leads and plugs recently? No cam position sensor in dizzzy engines mate. Yep, you need the whole dizzy as VW don't sell the HS seperately....the gits. Quote Share this post Link to post Share on other sites
VR6 0 Posted December 13, 2005 Oh ok - learn summat new every day :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 13, 2005 Oh ok - learn summat new every day Smile Thats because the hall sender inside of the dizzy provides the timing signal, on the coilpack models the CPS takes over that role... Quote Share this post Link to post Share on other sites
VR6 0 Posted December 14, 2005 My statement was still factually correct ;) (thanks for the info :)) Quote Share this post Link to post Share on other sites
Vr6_polo 0 Posted December 14, 2005 Ive changed the plugs, leads, rotor arm, dizzy cap, ignition module ect unless some 1 has info on which pins the diagnostic connector goes to on the ECU i cant get it on VAG as for running hot the temp never goes above 70oC when driving and ive got an oil cooler to help it just used to get the heat soak to the air filter like most Vrs anyway which has now been sorted with a custom made alloy heat sheild Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 14, 2005 as for running hot the temp never goes above 70oC Thats too low - as I said above, change the temp senders first... Quote Share this post Link to post Share on other sites
Vr6_polo 0 Posted December 14, 2005 ok ive just got a hall sender from bosch direct for £20 so VW can stick there complete dizzy up the u know what.... once ive done this i shall change the temp sensors like u suggest if it makes no differance Quote Share this post Link to post Share on other sites
Vr6_polo 0 Posted December 29, 2005 ok now im stuck unless someone can provide me with info on where the wires go from the diagnostic connector so i can get it on VAG...???? so far ive changed PLUGS, LEADS, ROTOR ARM, IGNITION AMP, BLUE TEMP SENSOR, HALL SENSOR and car still fells like its retarding the timing when its warming up Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2005 Speak to Stealth Racing. Vince is very good with the ECU pin outs. You'll need the ECU number before ringing him though as there's 3 types for the ABV engine. Quote Share this post Link to post Share on other sites
Vr6_polo 0 Posted December 29, 2005 Cheers do u happen to know there number? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2005 Aye, I know it better than my own number, LOL.... 01926 812259 Quote Share this post Link to post Share on other sites
