Dub Style 0 Posted December 14, 2005 I've got mk4 calipers fitted to the car but my font caliper o/s seemes to be siezed the car barely rolls and the front wheel heats up real bad and you can smell the pad burn............whats the remedy Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted December 14, 2005 New Caliper???? Fit Brembo Conversion!!!!!! Quote Share this post Link to post Share on other sites
Trig 0 Posted December 14, 2005 Can you not looob up the pistons on it? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted December 15, 2005 Check that the caliper carrier is centred over the disc. I had a similar problem with very noticable binding and continuous squeals from the front brakes, hot smells (mostly from the brakes !!) and poor fuel consumption. When I fitted the 288mm setup , I discovered that, somehow or other, one of the lugs on the hub to which the carrier is bolted had been bent out of position slightly, causing the brake to bind on one side of the disc. A bit of judicious blacksmithery brought it back into line. Together with new pads and discs, the problem was solved and she rolls completely freely. I had replaced the seals in the calipers too, so there was no chance that the piston was sticking. Best wishes RB Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 16, 2005 Was the caliper new? does the piston push out ok? Quote Share this post Link to post Share on other sites
Dub Style 0 Posted December 18, 2005 still working on this, the piston pushes out ok when you apply the pedal, i've managed lift back the rubber seal and its a lil bit rusty the piston that is, so i cleaned it up with a bit of sand paper, can i just apply a bit of copper grase to the piston? to help it. Quote Share this post Link to post Share on other sites
