scarlett 0 Posted December 19, 2005 morning all!!! quick question - hopefully with a quick and easy answer!!! new valver has Konigsports at the front and height and ride adjustable Koni springs at the back.... prob is the back currently sits higher than the front and needs levelled out... am refusing to raise the front so i need to find out how to lower the backs and what i need to do it.... any ideas how to do this? am gonna try and contact previous owner to get more info on exactly what set up it is.... cheers! :) Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 19, 2005 are they coilovers on the rear ? Quote Share this post Link to post Share on other sites
scarlett 0 Posted December 19, 2005 nope... unfortunateley not.... Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 19, 2005 then the height is not adjustable Quote Share this post Link to post Share on other sites
ben16v 0 Posted December 19, 2005 havent the koni top adjustable rear shocks got a circlip with 5 settings for height?? no idea how to change them though Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 19, 2005 havent the koni top adjustable rear shocks got a circlip with 5 settings for height?? no idea how to change them though Ar if it is those you can take the compression away from the spring then remove the circlip and replace in a lower groove.. what happened to the rear konigsports ? Quote Share this post Link to post Share on other sites
chrishill 0 Posted December 19, 2005 I was just going to say i saw a FK spring/koni damper combo the other day which had 5 height settings on the rear dampers. Quote Share this post Link to post Share on other sites
