Lanceevox 0 Posted December 19, 2005 I have been smelling gas when I start up my engine ever sense I bought my Corrado. Today I checked under the hood and I could see gas was coming out of a part toward the front of the engine. I have no idea what it is called. It runs out of the right front of the vr6 engine and from there a meshed tube comes from it. gas is leaking from the part. Is it ok to drive? How much will it cost to fix? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 19, 2005 If any gas is leaking out of anywhere don't even start the motor up or you will risk under bonnet(hood) fires or worse loose the hole car. Fuel(gas) vapour will ignite more easily It sounds like your describing the fuel pressure regulator?or fuel lines?not to sure pics, will help Quote Share this post Link to post Share on other sites
Lanceevox 0 Posted December 19, 2005 This is where it is leaking from, not sure if it is the part or the hose. THIS IS NOT ACTUALLY MY VR6 its just an example. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 19, 2005 that's the fuel pressure regulator.take the clip out from the side that holds it in place and pull it out you might find the rubber o-ring split and these are pennies to replace Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 19, 2005 here is a pic. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 19, 2005 Yep, found the same thing on Kevhaywire's car a couple of weeks back, the green O ring had just started to disintegrate... luckily we managed to get it out without dropping bits into the fuel rail... Quote Share this post Link to post Share on other sites
Lanceevox 0 Posted December 19, 2005 DO i have to disconnect anything before I remove the O ring? Will gas spill out everywhere? Do you know a step by step process. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 20, 2005 there will be pressure on the fuel rail so if you leave the car switched off for 10 minutes or so to allow the pressure to subside Pull off the rubber pipe connected to the fuel rail regulator and then pull out the metal clip that holds it in place. Wiggle the fuel pressure regulator out slowly and allow any pressure left in the rail to be released slowly. Its straight forward and once you have the regulator out you will see the fault. Try not to get any old bits of seal left in the fuel rail as this could clog an injector. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 20, 2005 I'd leave the car longer than that or disconnect the battery neg as you don't want the fuel pump aftter run kicking in! Quote Share this post Link to post Share on other sites
Lanceevox 0 Posted December 20, 2005 I am sorry I am totaly clueless but where can I get a new O ring? Are most O rings compatable from car to car so I could just pick one up from Kragen? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 20, 2005 Kargen? Karmen? If you go to your VW dealer they will have the part for you,not every seal is the same it needs to be fuel resistant. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 20, 2005 I'd leave the car longer than that or disconnect the battery neg as you don't want the fuel pump aftter run kicking in! They have after runs with the ignition off? Quote Share this post Link to post Share on other sites
Lanceevox 0 Posted December 20, 2005 OK, I took off the clasp and the regulator. The green O ring seemed like it was in good condition, NO cracks or splits. the other rubber ring seemed alright as well. the filter was also in ok condition. I had a little gas spill while removing the regulator (about a cup of gasoline spilled...). I am letting the engine air out and a rinsed the engine out a bit with some water. I will try starting up the car later on in the day to see if there is still a leak. Is there anything I can do to make sure the gas fumes disapate? Should I continue rinsing the engine with water to relieve it of gasolene? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 20, 2005 The gas will evaporate on its own.If you leave it for a while it will be fine. So you found no problems with the seals? Quote Share this post Link to post Share on other sites
Lanceevox 0 Posted December 20, 2005 The seals were fine. I decided just to put it back in and push it in nice and tight. I started up the engine and no gas leak what so ever. I ran it around the block and still no leak. I think I have fixed it for the moment. I think it just leaks a little inconsistantly. Quote Share this post Link to post Share on other sites
