cymru-corrado
more bloody cooling problems
my car decided to overheat and waz its coolant out y'day morn on way to work.was about 10 miles into journey.only around half a mile from work so parked up ok.after work topped up coolant let run to get rid of airblocks ran engine,fans were cutting in around 98-100 degrees.drove home no probs temp didnt even get above 110 degrees on way home
well guess what exactly the same scenario happened today.overheated topped up fans were kicking in earlier though at 92 degrees then shutting off at around 88.drove home gauge was 94-96 the whole way apart from a slight bit of second gear stuff near home then it only reached 100.
anyone know any ideas on the last two mornings though as cant be bothered to keep sorting it out every night after work.thinking of getting a compression check done to check the head gasket.
car has had new thermostat and fan switch also recently.
