mgbv8mike 0 Posted December 24, 2005 I'm just about to do an oil change, and find that I've got a 'spare' wire in the engine bay .....yellow/black with a female spade....seems to run from the starter motor solenoid area (VR6) to somewhere near the twin fans.....any ideas ? Quote Share this post Link to post Share on other sites
kop10320178 0 Posted December 24, 2005 same as me fella i have spent hours trying to find were it goes i put a post out as well? jay Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted December 24, 2005 i think there is a spare wire, not 100% but sure i saw a post on this... Quote Share this post Link to post Share on other sites
RW1 0 Posted December 24, 2005 It's a spare wire unless the factory fitted the oil pressure and voltmeter gauge. The wire is the oil pressure gauge sender wire when it's fitted as a single pole sender (using a banjo coupling at the oil filter head) and the oil pressure switch is still used for the red dash LED & buzzer. When not in use it's tucked up behind the fan using a coolant hose plastic "C" shoulder clip to secure it from dangling about. . Quote Share this post Link to post Share on other sites
