jekvr6 0 Posted December 28, 2005 i have always been able to hear i vacum noise on my vr6 from the top back of the engine i think it just the noise as it goes though what vw call the damper just woundered if it the same on all c vr6 or do i have a leak Quote Share this post Link to post Share on other sites
Taggart 0 Posted December 28, 2005 Check the bit of foam inside hasn't come loose and moved into the pipe. Are you having any idle problems? Quote Share this post Link to post Share on other sites
jekvr6 0 Posted December 28, 2005 no idle problems at all i will remove it and check thanks Quote Share this post Link to post Share on other sites
andy 0 Posted December 28, 2005 It does make a noise, like rushing air, in my experience they all do it. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 28, 2005 Yep that's the sound of the VR doing it's sucky sucky thing :-) You should hear it with a Schrick! Sounds like there's white water rapids going on in there. Quote Share this post Link to post Share on other sites
