Rick 0 Posted January 3, 2006 hi ppl, i have a 92 vr6 slc (LHD). i think the shaft that connects my steering column to the steering rack may be needing replaced, there seems to be a bit of play in the joints and was wondering if this part is interchangable between the different corrado models or even golfs etc. will the part have to be from a LHD car?????? anyone ever changed this part. thx ppl Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 4, 2006 Are you sure it's play in the universal joints? It's more likely to be play in the steering column, or the rack itself. The UJs rarely wear out. The adjustable steering column was the culprit on mine, and I think many higher mileage Cs are showing the same problem. Quote Share this post Link to post Share on other sites
