**Ian**
Gear change cables
How do you replace them :?: On my project one of the ends is snapped off, I have a good set on my spare valver. Do you have to drop the exhaust and heat shield to get them out :?
Which end has snapped off?. If its at the gearbox end the plastic end bits that join onto the shift tower are replaceable. If its at the lever end you will have to drop the exhaust and remove the heat shield and shift housing to replace the cable.
