saysomestuff 0 Posted January 8, 2006 Hi all, Haven't had a chance to have a proper look but there's a puddle under my gearbox, where should I be looking for the source? Any common failures? Cheers, Cole Quote Share this post Link to post Share on other sites
RW1 0 Posted January 8, 2006 Sure it's the gearbox???? Gear oil, water or engine oil???? If so, four places generally, filler plug on front face, drain plug at the back under the differential bit, around the drive shafts seals above the drain plug on either side of the differential and finally, the gearbox driveshaft input seal inside the clutch bell housing which will show up as a leak dripping off the bottom of the bell housing. . Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 8, 2006 Does it smell Nutty? Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted January 8, 2006 Dunno, only had a brief look. I will investigate further tomorrow, seems pretty clear for engine oil (andd no, it's not water :lol:) Thanks guys Quote Share this post Link to post Share on other sites
Walesy 0 Posted January 8, 2006 Could it be the clutch slave/master cylinder? Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted January 8, 2006 hmm, good thinking man, I'll have a check 8) Quote Share this post Link to post Share on other sites
