ardandy 0 Posted January 21, 2006 Is there something that should be plugged into the white part? Also, what the hell is it? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 21, 2006 Looks like a loom for an extra relay - not of the ones next to the fan controller look standard - have you got Aircon fitted?? Quote Share this post Link to post Share on other sites
dinkus 10 Posted January 21, 2006 He must have - those relays are Diavia ones... Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 21, 2006 Yeah, aircons in the car, although not sure if it works as its too cold outside to test it! Is there anything missing? What is all that fuse type block for? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 21, 2006 May just be unused... test the A/C first then worry about that later... Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 21, 2006 Is there any easy way of testing the ac, its about 1-degrees C outside so I cant tell with sticking my hand infront of vents! Also, only 1 & 2 currently work on the blower! :( Quote Share this post Link to post Share on other sites
dinkus 10 Posted January 21, 2006 Start car, put vents on as fast as you can, push the norm and max buttons - you should hear the AC compressor kick in - the engine will change noise as the extra load is put on. Quote Share this post Link to post Share on other sites
