potatonet
putting a VR6 radiator in a G60?
let me rephrase that, can i put a VR6 radiator from a corrado VR6 into a G60 has anyone looked at the mounting points? fluidyne makes an aluminum radiator that is guaranteed for life and its for a VR, wondering if I can put it into my G60.... =-/
Trying to find out if its possible myself. Supercharged reckons he's seen one with a VR Radiator, VR Radiators are the same as Golf Rallyes, 630mm wide with the hoses both on the right. Can't see it being a problem apart from the Slam Panel brackets, but i'm sure you could make something up.
nice avartar hahahaha.
I just found out that G60 radiators have 6% more coverage than a VR, PWR makes a radiator thats 415 and is thicker than normal for more fluid flow, I might use it just because I am going to be running 24-25 psi... eek
