STORM 2 0 Posted January 29, 2006 Anyone know where the relay is for the oil temp sensor which goes from the oil filter housing (presumably via a relay) to the MFA? I've replaced the sensor with no joy.... and still getting "---" on the MFA display Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 29, 2006 Don't think there is a relay... Quote Share this post Link to post Share on other sites
Yandards 0 Posted January 29, 2006 Wiring diagrams I have don't show a relay either. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted January 29, 2006 so presumably it goes from the sensor straight to the MFA? Quote Share this post Link to post Share on other sites
Yandards 0 Posted January 29, 2006 Yeah the wiring diagram is just a straight run of wire, according to my info it should be green wire with a black stripe on it. It should run straight to the back of the fuse box and is on the G2 plug at terminal 1 if you wanted to test the wire. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 31, 2006 hi storm i had that in my mk2 try disconnecting the battery thats what i did and it reset it all if that doesn't work get someone to hlod the mfa button in while you disconnect the battery Quote Share this post Link to post Share on other sites
