2_Door_fun
Inner CV boot
Both driveshafts off and both need new innerboots. How do you fit the new boot. I have a Porters manual but it does not really focus on the C.
I have a few months back fitted both outer boots. I just tapped the joint off without removing the shaft. Can you remove the outboard joint and slide the inner boot up or not?
The porter manual talks about Circlips and pressing the joint off. I have no circlip at the shaft end???
As an edit....
Just removed nearside shaft and yes a circlip. joint popped easily. It would appear that the off side shaft has had a boot on in the past. Previous owner lost said circlip and has hammered top off shaft to spread it a little. Thereby holding joint in place......GREAT :x
Anyway now I know how they pop. Just got to solve this one now....!
