chrisw 0 Posted February 4, 2006 I am looking for some help on adjusting the brake compensator valve. Could the Bentley manual possibly be more cryptic? I don't have a clue what the recommended ABS procedure is on about, seems to be saying you need to plumb a load more stuff in to test it. I assumed you would just attach pressure gauges in the bleed screws and make sure the front/back ratio is ok (with the ignition on?). Has anyone done this and where do you get the gauges from? Chris Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 4, 2006 The US abs system is alot different to the ones we have over here... Quote Share this post Link to post Share on other sites
chrisw 0 Posted February 6, 2006 Anyone done this then? Where did you get your guages from? Quote Share this post Link to post Share on other sites
