exturbo2003 0 Posted August 30, 2003 okay two probs i need help with 68 mm pully sns chip rebuilt and ported charger 3.5 bar fuel pressure reg bosche plugs what boost should i get on my mfa and what co at the sample pipe. also is there a shorter belt listed for the smaller pulleys or am i stuck with standard. thanks in advance for any help :lol: Quote Share this post Link to post Share on other sites
Si B 0 Posted September 1, 2003 With a 68mm pulley and Jabba chip, S4 charger, de cat pipe and induction kit I am getting up to 5,800 on the boost meter with about 3,000 at 3,000 rpm. Re the belt, you should get a new tensioner end cap with the pulley kit which makes the tensioner longer and thus takes up the slack in the std belt. You just chop off the old end and the new cap slides onto the tensioner. Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted September 1, 2003 3000 on the boost meter at 3000 rpm? do you mean the reading on the mfa? if so mines 1980at 5800. didnt fit the end cap as didnt want to cut the tensioner but will try it tomorrow, thanks Quote Share this post Link to post Share on other sites
Si B 0 Posted September 2, 2003 By boost meter yes I do mean the MFA reading, although as I am still trying to find someone who can tell me what the 4 digit readout equates to in psi. Your reading is a lot lower than mine was although thinking back, I wonder if I managed to accidentaly switch the digi rev counter on instead!????? cos the readings were very similar to the rev readings. If this is the case then sorry if my previous post confused you. Please could you confirm what sequence of button pressing you used to activate the thing and then I will have another look at it this weekend. regards Simon Quote Share this post Link to post Share on other sites
spoier 0 Posted September 2, 2003 Strange, the MFA on my '90 US car reads out three numbers for intake vacuum... > Intake vacuum = psi > 172 2.9 > 192 5.8 > 211 8.7 > 228 11.6 > 242 14.5 > 255 17.4 But I did find this info: the book says 1400 is 5.8, and 1600 is 8.7. this is for up to august 1990. the chart for 91-92 stops at 1100 for some reason. but on that chart, 1100 is 1.5 psi, so looks like the same thing. since you have the motometer, it is easier for you to figure out. 1000 is atmospheric pressure at sea level (not sure where you live) or 0 psi. every 100 over that is 1.47 psi. .... so if that's right 3000 = 29.4 psi?!?? yikes that cant be right - oh well Skye Quote Share this post Link to post Share on other sites
spoier 0 Posted September 2, 2003 MFA Instructions: MEASURING MODE TEST =================== measuring mode that provides a display of measured fuctions during vehicle operation. 1. Set MFI memory switch to position 2 2. switch ignition on 3. press and hold MFI mode select button. 4. switch ignition off , then back on 5. release mode select button (first function is displayed,see chart) 6. start engine and drive vehicle 7. press and release mode select button to advance display FUNCTION/DISPLAY mode/symbol displayed Test sum of programmed bytes * - Intake manifold (mbar)** clock Engine RPM *** km/h Momentary fuel consumption L/100 km Signal from speed sensor **** km Oil temperture (c) oil temperature Ambient temperature ambient temperature *= Displayed value has no importance **= The VDO multifunction indicator displays intake manifold vacuum as a decimal numeric value instead of in mbar. Chart in manual ***= If incorrect go to trouble shooting section (not included:() ****= Numeric value should change. (formula for Can. not included) So, make sure the MFA switch is on "2" and cycle once (clock symbol showing) At least that's how it works on my car. Skye Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted September 3, 2003 start vehicle, switch mfa to position 2, holding in the select button turn the engine off and restart. the mfa should change display to C10, press button once and you now have the boost reading. as far as i know 1880 is 1 bar/14.5 psi. mine reads 1970 but a boost gauge reads 15 psi, so about right. the book says 1400 is 5.8, and 1600 is 8.7. this is for up to august 1990. the chart for 91-92 stops at 1100 for some reason. but on that chart, 1100 is 1.5 psi, so looks like the same thing. since you have the motometer, it is easier for you to figure out. 1000 is atmospheric pressure at sea level (not sure where you live) or 0 psi. every 100 over that is 1.47 psi. thats about right for mine Quote Share this post Link to post Share on other sites
