andiG60
16v ill and getting worse. and ideas????
hi all. following up regarding an earlier post. my 16v starts fine and runs perfectly for about 2-3mins, then all hell breaks loose and the engine starts backfiring and rocking back and fore and is utterly undrivable. :x
suggestion from you all before as follows, and i have so far
changed lamba
changed temp switch
changed leads
changed coil
changed all the piping from filter to inlet manifold ( due to holes)
Fiddled with mixture a bit ( but nothing so reset it)
Has anyone got any other suggestions ( it does run a little better if i disconnect the temp switch when backfiring) as the car has been off road for 6 weeks now :roll:
