designrob
Clutch Dilemma!
I need some advice pls!
To add to the long list of things going wrong with my car at the moment, the Clutch now needs replacing! :(
I have been quoted £500.00 for a genuine VW Clutch Kit inc Fitting.
or £330 for a After Market LUK Clutch!
If I dont go for the VW Clutch, will there be a great difference in the feel etc? Is there much difference in quality?
cheers
What car is this?
The VW clutches are usually a mixture of LuK, SACHS and Valeo and are alot heavier duty than the pattern kits...
The difference in price should only be about £20...
Looks like a Rado VR6 from the stud pattern on the car in his avatar...
Eagle eyes! :-)
In the case of the VR, I'd always use a genuine one as the patterns, despite being made by the same supplier to VAG, are sheeeite. I'm not getting into how many I've had replaced under warranty.....suffice to say, the last one was done 20K ago and was VAG and is perfect.
I would also recommend replacing the flywheel (£75 exchange) to ensure all mating surfaces are 100% true, or you might get judder problems.
is it possible to get the flywheel just skimmed rather than replace ?
