VRTrickster
VR6 CAM ALIGNMENT
Any old bit of flat metal will do the job, just place it in the grooves on the end of both camshafts. Its as good as the tool as both shafts have to be exactly flat in order to get a peice of metal in both grooves at the same time.
There are slots off center at the end of each cam. You can see that that one way round the bottom edge of these slots is in line with the top of the head casting (correct), and the other the slots are above by about 5mm (incorrect). I didn't use one and managed to get it together ok.
