matth76 0 Posted February 24, 2006 Hi I know when fitting lowered suspension the 4 wheel alignment has to be done. However... will I need the camber adjusted as well with a 35 or 40mm drop? I know you do with big drops but is it necessary on a 35 or 40mm drop? Thanks. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 24, 2006 Given that you'll be putting different dampers onto the car, and you can't even guarantee that you'll be putting the camber back the SAME as it was before, I would say it's vital that you check it... Any time you remove or just loosen the two big bolts that connect the hub to the dampers you need to check and adjust the camber. Quote Share this post Link to post Share on other sites
