AdamB
Is this my water pump?
I've just found a small water leak in the engine bay - I had alook and found it coming from a small pump to the right of the engine (where the plug leads come up). I moved the pipe that it was coming from and found it cam away from a small pump. I've taken the pump out and I'm about to order a new part, but I want to make sure I know what it is first. There is a Bosch part number - PAA 12V 0392 020 054 (I think the last number is 4 - it's a bit worn, so it could be a 1) It had 2 pipes at the bottom, connecting to a plastic cap, and a plug on the top
Cheers
Adam
Thats your auxilliary water pump. Its quite common to have a leak in one of these, I've replaced 2 before, the newer ones are better than the originals. £62.98 from GSF including 10% discount.
That went recently on mine too! I got one from ECP for about £70, as far as corrado's go its a cheap and easy fix :D Make sure you take the rubber mount off before you bin it!
