blue95
Camber Adjustment in MK...Help!!!!???
Almost have my car back on the road, hoping to have some pics up soon.
Can anyony recommend a camber adjustment place in MK?
Also do VW do it? and how much do they charge?
Thanks!
STS wheel alignment are pretty good...but they aren't exactly cheap!! :?
They are based in Bedford..so not too far from you :wink:
When you say not cheap????
Should I start saving my pennies?
How low is your car?
conventional alignment kit hangs over the wheels and can be a problem on really low cars, not many places have the kit to do a corrado that's 60mm or lower than standard.
You could drive up to Stealth , north of Daventry at Southam and they'll use their expensive VW kit to do the job very accurately, but you're looking at 75 quid plus I think.
Kwik fit etc, should do basic 4 wheel alignment for around 30 quid, which is fine for most cars. The independant garage I use is 'John Spademan's - Motor Engineers', tel. 262446, in Stony Stratford, but them I'm biased as my Dad works there :) - they got mine perfect though on 40mm lower eibach springs.
David.
:lol: :lol: ....it's not that bad really! They come well recommended and they did a good job on mine!
Cost me £47 two years ago to get the camber and alignment set. Which is prob a bit more than a cheap Kwik-fit alignment. But I figured I was better off getting the job done properly :wink:
Thanks for that guys!
I was having an offline chat with Bally, he recommended John Spademan as well.
I have it booked in for a service on Friday as well, they said they will take a look to see if it needs doing and then advise.
Out of curiousity I rung VW, they wanted £170 + VAT for tracking/camber!
My local one has just quoted me £154 (not sure about the VAT?)
I wonder if that's before or after they've realised how long they'll struggle to get the siezed track rods adjusted, they'll probaly add another 2 hrs labour to your bill then.
No probs S... :wink:
Yeap I'd recommend both John S & for low car STS..
Ive been using STS for the last 2yrs & there work is excellent!
