rado 0 Posted March 2, 2006 hi am wondering if anyone of u can help me i have a 16v 91 corrado when i drive it and stop the coolant bottle overfills sometimes and comes out but doesnt overheat but the light comes on dash from bottle sensor was wonderin if common problem for over pressurisin system ie problem with block or poss water pump on way out or headgasket which it proberly is. :( i think the thermo has been taken out as temp gauge is low when drivin Quote Share this post Link to post Share on other sites
Valerian 0 Posted March 2, 2006 these are the possibilities..... blown headgasket cracked cylinder head cracked cylinder block Faulty expansion tank cap Faulty thermostat or air lock in the cooling system somewhere I've found that a common reason for the temp guage to read low is because the two wires to the two coolent sensors are connected the wrong way round. However.....from what you describe.....may well be headgasket failure Quote Share this post Link to post Share on other sites
