GazzaG60
What clutch and flywheel for 02m
Guys
those of you who are 02m users or have been what clutch and flywheel setup are you using. is it any good, any judder. how much power does it hold for you and does it work well.
Thanks in advance
i think it the 240mm clutch as used in tt a3 seats etc. if you running serious grunt use the cupra TDI clutch. it'll hold over 350bhp and as much torque
thanks
i know its 240mm but was after opinions on other types and maybe the flywheels used. im planning on a light flywheel but have heard reports of bad chatter. was gonna use a 6 puck nut will probly go for the tdi one like you said. good call.
I am using a light (steel) 240mm flywheel with uprated PP and solid 6 puck clutch. It chatters badly.
