Ronan 0 Posted March 8, 2006 Well, today gave me my first experience of sitting at the side of the road with the bonnet open. My car overheated in traffic, never had that problem before, and had the thermostat replaced 3 months ago, so hoping its not that! Also, my water temp gauge doesnt work, so my first clue to it overheating was the coolant level light flashing - which I thought was because it might be low on coolatn, it's done this before when it's needed topping up. Cue steam coming from under the bonnet - oops! Re-filled it with water (after phoning work and telling them I wouldn't be in) and limped it home, with the oil temp still reading quite high (obviously I can't watch the water temp). So not sure what it is, and it's raining, so can't be assed to go check. Fun! Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted March 8, 2006 .....did your cooling fan cut in at any time ? Quote Share this post Link to post Share on other sites
Ronan 0 Posted March 8, 2006 I dunno mate, I'm gonna go and check when it stops raining. I couldn't hear it, you can't hear much over my engine tbh. Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted March 8, 2006 no doubt that you`ll get all the advice you`ll ever need once you been able to give it a dose of looking at to give us a few clues to your problem :thumbleft: Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted March 8, 2006 my fan switch died a few weeks back...same problem solved with new switch. deffo worth a look. you can just bridge the contacts on the connector to test its not a fuse/bad wire etc.. Quote Share this post Link to post Share on other sites
.Rich. 0 Posted March 8, 2006 If the switch dies, does the light blink constantly? My light is constantly flashing even though its cold and i have a good constant water level. Quote Share this post Link to post Share on other sites
Ronan 0 Posted March 8, 2006 Think my problem is the fuse - had a check and it was burned out. Gonna go get some more (as spares too) later on. Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted March 8, 2006 If the switch dies, does the light blink constantly? My light is constantly flashing even though its cold and i have a good constant water level. the switch in the coolent tank can die, i had to replace that too. Think my problem is the fuse - had a check and it was burned out. Gonna go get some more (as spares too) later on. good stuff :-) not sure if the 60 has that black box in the engine bay but may be worth checking the fuse on that to, just 30 amp fuse wire if i recall. Quote Share this post Link to post Share on other sites
