iow_corrado_g60
Keeps Going.......??
Hi lads my wheel bearing keeps going i've been told that the shaft or whatever it sits on is heavily worn on one side and idea's?
As I really dont know what it is at mo?
Cheers Andy
Hmmm....assuming the rear ones? Either overdoing the torque..Ie none or there is wear on the underside of the stub axle outer bearing face.........?
If you have been told the shaft is shot that would mean a new outer CV joint as the splined bit that goes through the bearing is on that? Don't ask why I am posting this at 4 in the morning!
