gus16v
Can I fix my heater control box or is it an ebay job???????
any ideas please as it's really cold and the heater only works on postion 4!!!!
cheers :)
The resistor will have gone.
You can by pass it, with a bit of wire. Sounds a bit cowboy ish I know but it works. ANd, its much cheaper than buying a new fan.
Its quite easy to get the fan out too. Take the shelf out under the glove box, lie on the car's floor and look up. Press a few clips, twist it and it'll drop out.
Happy days
T.
Thermal fuses/resistors are only about 80p from Maplins - for the sake of not overloading the circuit if the motor's on it's way out, I'd rather replace a fuse... ;)
Though it might be that the metal strips behind the fan speed knob aren't making proper contact - that's what it was on mine...
As far as the temperature goes, if your passenger footwell isn't flooded (heater matrix gone/bypassed), then you may have an airlock in the cooling system
Not that this has been done to death or anything! :lol:
Yep, closing as this has been extensively covered!
Use the search:
heater AND setting and resistor
Or something similar.
