ardandy 0 Posted March 21, 2006 After much searching/reading etc about lowering the C, someone at some point said that after 13 years, chances are its 20mm lower than it was from day 1 anyway. What should a standard C be? And how/where from should I measure the height of it from the ground? Quote Share this post Link to post Share on other sites
biggrim 0 Posted March 22, 2006 IIRC you measure from the wheel arch to the centre of the wheel matey. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 22, 2006 The springs sag slightly over time, and the top mounts compress too, so yes it probably is a good few mm lower than originally... Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 also it depends which side you measure! the drivers side is almost always lower (the ones i've seen anyway) due to the cars being RHD. the engine and driver are both on, or biased towards, the right hand side, so that side's suspension tends to sag more over the years. Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 The springs sag slightly over time, and the top mounts compress too, so yes it probably is a good few mm lower than originally... the top mounts can also 'stretch'! my passenger side mount has stretched by about 10mm!! or perhaps i should say its been pushed up? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 22, 2006 id say the engine is more over towards the passenger side,plus you have the gearbox,battery,washer bottle,abs pump etc on the passeger side,plus roads tend to slope towards the left so there is more strain on the passenger side Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 22, 2006 ....and the standard ride height of the VR6 is..... Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 er..... not in mine. the engine is definately towards the driver's side mate. and apart from the g/box those ancilleries you list weigh fek all. i have never seen a vr sagging more on the passenger side. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 22, 2006 ....and the standard ride height of the VR6 is..... to high :lol: Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 22, 2006 Like a fine whiskey, my VR6 has been lowered carefully over 13 years, for that authentic driving experience. Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 mine seems to be a completely different height at each corner! i can also feel my front left shocker moving on full lock! nice Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 22, 2006 around 66cm from the ground to the centre of the arch,going through the centre of the wheel,thats when its on standard wheels Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 22, 2006 er..... not in mine. the engine is definately towards the driver's side mate. and apart from the g/box those ancilleries you list weigh fek all. i have never seen a vr sagging more on the passenger side. i meant the weight of the engine is mainly towards the passenger side,and those ancilleries do weigh quite a lot actually Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 how is the weight of the engine, that is sat towards the driver's side, mainly toward the passenger side? and in relation to the engine, those ancilleries just don't weigh alot at all. sod all. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 22, 2006 Incorrect. The VR has a natural tilt on the driver's side due to the weight of the engine block. The Gearbox and such weigh very little in comparison. If the weight was more concentrated on the passenger side, then the gearbox mount would be a lot beefier than it is now. Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 Incorrect. The VR has a natural tilt on the driver's side due to the weight of the engine block. The Gearbox and such weigh very little in comparison. If the weight was more concentrated on the passenger side, then the gearbox mount would be a lot beefier than it is now. Exactly. I have always assumed that it is a compromise due to the car being designed as a left-hooker? It would be more balanced as a LHD with the drivers weight cancelling out the engine weight bias. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 22, 2006 well do you think vw just dropped an engine and said ok that will do there?they work the weight out so it evenly distributed,when i took the engine and gear box out of my car,guess what happened,the gearbox end dropped even though i thought the weight was even,and i used an egine stabiliser bar..oh and i forgot 25 litres of water doesnt weigh anything :lol: and neither does a battery Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 yep they do (work out the weight distribution, not just drop it in!) on a left hand drive car. the conversion to RHD compromises that balance i would think. just my opinion though. you have a 25 litre washer bottle? fek me. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 22, 2006 lol..i forgot to put the . in,but its actually 4 litres,still weigh a bit though Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 22, 2006 25 litres! You must do a lot of rallying or something! Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 sorry, seriously hijacking your thread mate :( just for a laugh, i'm going to measure all four corners on mine in a minute - should get a good spread of results! Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 22, 2006 So, from floor to wheel arch? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 22, 2006 well do you think vw just dropped an engine and said ok that will do there?they work the weight out so it evenly distributed,when i took the engine and gear box out of my car,guess what happened,the gearbox end dropped even though i thought the weight was even,and i used an egine stabiliser bar..oh and i forgot 25 litres of water doesnt weigh anything :lol: and neither does a battery The engine weighs 170ish Kilos and the gearbox weighs about 45-50 I'd say. Most able bodied men can remove a gearbox themselves when doing a clutch, so you can lift an engine block aswell can you? If the engine block is biased to the offside of the engine bay, where do you think the weight is going to be concentrated - durrgh, the offside of course. It's not freakin rocket science is it, no matter how hard you try and defend your argument with silly comparisons to washer bottle and battery weight :roll: Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 22, 2006 the cavelry........ :) (sound of horses hooves and horns in the background) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 22, 2006 LOL.... Dazzy and I have 'history' mate, don't worry about it..... we always argue over stupid trivial things :-) Quote Share this post Link to post Share on other sites
