willg 0 Posted March 24, 2006 does anyone now what gets wet when it rains heavily. my corrado is very stutterey only after a really heavy rainful in the morning. it clears after i have driven it for 5 min (assume the water evaportates), it is the same as when water gets in to a disributor but tthe vr6 does not have one. any ideas much appreciated will Quote Share this post Link to post Share on other sites
VR6 0 Posted March 24, 2006 The slightly earlier VR's do have a dizzy ... Quote Share this post Link to post Share on other sites
willg 0 Posted March 24, 2006 mine is a 95 is that classes as an early Quote Share this post Link to post Share on other sites
VR6 0 Posted March 24, 2006 Nope, that will be a coilpack unless it's had an engine replacement for an early one :) Quote Share this post Link to post Share on other sites
willg 0 Posted March 24, 2006 still has the original engine and yes it has a coilpack, can't see any where where water would get in Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 25, 2006 Look in the scuttle panel area, it may be that you've had water ingress into the ECU. But this is classic symptoms of a coil pack or HT lead problem, tbh. The general dampness after a night of solid rain is enough to increase the conductivity of the parts of the coil pack that aren't supposed to conduct, if there's any weaknesses in the structure, no matter how small ... Quote Share this post Link to post Share on other sites
craigowl 0 Posted March 25, 2006 Coilpacks get cracked with heat and age. If you spray a mist of water onto coilpack with engine idling you may get engine faltering which will confirm this is likely to be problem. Out of bright light you may see arcing to coincide with the engine stuttering. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted March 25, 2006 Have you changed the leads or coil pack at all? Quote Share this post Link to post Share on other sites
willg 0 Posted March 25, 2006 the leads have beed changed about 2 months gao but not the coil pack, oh and the spark plugs Quote Share this post Link to post Share on other sites
