ben221000
Radiator fan
The radiator fan is playing up, it comes on when the engine is at normal running temps (90degs) and doesnt turn of by its self. I have to un plug the wires. My car never overheats so im not worried about that.
Is there a sensor somewhere that may be faulty?
or anything else that could be up?
I would be greatful of any help. Cheers
Check your afterrun sensor, it's on the left side of the engine, right in front of the intake manifold with one single wire connected to it. Unplug the wire, if your fan shuts down, the sensor is down the drain, if it keeps on going, you have a problem in the wire leading to the sensor...
