korayus 0 Posted March 30, 2006 Hi, I bought g60 in very bad condition and I'm trying to make it like new. Lots of part has changed and still changing. The ABS light is on and ABS not working. And also rear brakes completely not working. What do you thing the problem is? Could it be ABS sensor problem? or something is more serious problem? Thanks in advance. Koray Ustuner Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 30, 2006 It could be both handbrake mechs seized or the calipers themselves due to old fluid but first of all I would check the rear brake compensator valve - these can be unseized with lots of WD40 and a large hammer! Quote Share this post Link to post Share on other sites
korayus 0 Posted March 30, 2006 Thank you very much. Tomorrow I will try to check brake compensator valve. What its look like? And where is the location of brake compensator valve? Thanks again. Koray Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 30, 2006 3cm square box on the rear axle on the passenger side with brake pipes running to/from it ;) Quote Share this post Link to post Share on other sites
korayus 0 Posted March 31, 2006 Thanks for the info. I am going to get the hammer adn WD40 now :) hope it helps. Koray Quote Share this post Link to post Share on other sites
korayus 0 Posted March 31, 2006 is this brake compensator valve? Koray Ustuner Quote Share this post Link to post Share on other sites
