Shaggy 0 Posted April 3, 2006 Calling all Water injection people.... before i head out and try the aquamist forum. Just thinking about adding in a 10% quantity of Nitro methane fuel into my water/ methanol mix?? i ve heard this can give quite good gains?? I ve worked it out that, my percentage amounts would be 60% distilled water 30% methanol 10% Nitro methane fuel (R/C car fuel) I wouldnt have thought this small amount would cause any damage to the internals would it?? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted April 3, 2006 But does the Nitro fuel have some sort of oil in it that acts as the lubricant for the little engine?? Wouldn't that be harmful, bit like putting diesel in the car???? Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 3, 2006 not totaly sure?? this is what i am trying to find out, i have just had a look on the aquamist site and there is a big topic on this particular subject, its 9 pages long so must have some info on it, i think the oil in the R/C is a caster based oil, and with this water down may not have an effect?? again its all questions at the moment, although there have been a few very suprising gains from going down this route albeit with greater concentrations on the R?C car fuel, up to 70BHP on a particular cosworth :shock: Quote Share this post Link to post Share on other sites
keithmac 0 Posted April 4, 2006 Just make sure you don`t wreck the WI pump, they do a viton seal kit for it of you`re unsure. I`m going over to (near) direct port injection, always use plain de-min water, going to try and advance the timing/ lean the mixture to gain power with the water as knock-prevention, using Spark and fuel map 2 if the WI fails it defaults to the safe maps just in case.. Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 4, 2006 just looked on the aquamist forum, a guy on there tested a few combintions and the best for performance was just distilled water! and also mentioned that if planning to get the car setup methanol was an easier fuel to add into the mix for extra performance, but if you plan to keep the W/I just for cooling then Distilled water will do the job just fine. so i may scrap the R/C car fuel idea and just run with my 70/30 Water/methanol mix. it is also mentioned that you will only get a real effect if nitro is mixed with methanol 50/50 this will give the greater gains. i am no expert on W/I so cant really say if any of this is true or not. http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=451&start=120&sid=477d9ed492f6764e23fd3395a2cd997a Quote Share this post Link to post Share on other sites
billinjah 0 Posted April 4, 2006 mike are you using the kit we all got off gibber? Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 4, 2006 Yeah mate. it has turned out to be quite a good kit for the price. Quote Share this post Link to post Share on other sites
billinjah 0 Posted April 4, 2006 cool havent fitted mine yet did you find a tap for the fogger? are you boot mounted or bay? Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 4, 2006 yeah got a tap from ebay, managed to find a cheap tap and die set (£5) that included the tap i needed :) I have mounted mine in the boot at the moment and it seems to work quite well, my water tank is only supported by cable ties at the moment as i havent had time to make up brackets yet but it seems to be holding. Got to tidy it all up a bit, but the main thing is that it all works! :) Quote Share this post Link to post Share on other sites
keithmac 0 Posted April 4, 2006 Running 50/50 you`d definitely have to make sure the pump was viton sealed. Some people use WI as a 5th injector with the meths etc as added fuel, problem is you have to account for this while mapping to a degree, or run rich. Run plain water and it`s transparent to AFR`s, so you can map it very easily without worrying what you`re injecting is effecting the wideband readings. It`s all down to personal preference what mix you run, I prefer to use it for detonation, heatsoak control rather than extra fuel. The Aquamist site is your best bet, there`s a lot of info to take in. Quote Share this post Link to post Share on other sites
