Ronan
Fuel pressure
Since having my car on the rollers at RKE, we've been trying to work out what could be wrong with my car except the belt slip. One of the things (alongside cam timing) could be the fuel pressure - wat sort of reading should I get bearing in mind I don't have a 3.5bar FPR?
Pump is 4 Bar
There is a procedure in the Bentley that says it should be 2.5 bar increasing to 3 when you remove the hose off the manifold from the FPR at idle...
