LowG
Rpm wire?
Hi I am trying to find out the rpm signal wire that sends the signal to the distributor on the 16v. I think its the green wire located G1 position 12 on the fusebox. I have lost my bentley so have no means of finding it out, can someone with a bentley check it out just to double check. It should be a green/black or green/grey i think. It should be the same for 16v or G60.
thanks guys
on the g60...
the wire from the coil supplying the rev counter is green as far as i can remember.(could be black,cant just remember)
and the hall sender wire,green/white?
sorry,memory's a bit sketchy.
neil. :)
