cymru-corrado 0 Posted April 13, 2006 is it poss to change radiator without removing slam panel etc, i had a little poke about and seems like a can disconnect and remove fan quite easily then 4 bolts holding radiator in place removed and with a bit of jiggling should come out, this the case and how long it take approx 2 hrs? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 13, 2006 What engine?? Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted April 13, 2006 you can defo do it on a 1.8 16v Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted April 14, 2006 all done had to take horns out though to get at screw that fix rad to the plastic liner thing which directs air onto the rad. need 1 screw though as currently have rad fixed with 3 screws.all running ok though. Quote Share this post Link to post Share on other sites
