iow_corrado_g60
is anyone running??????
is anyone running 4 stud alloys with a 25mm offset!
and if so do they go on ok without spacers or do they need spacers!
any help would be great cheers lads!
the alloys i have are 4x100 57.1 centre bore and a 25mm offset they are 7inch wide! thanks andy
if the standard g60 runs et35 with 6.5j wheels,,,
then your new wheels will stick out of the arches by a further half inch.
no need for spacers.
neil. :)
They will sit Quite well in the arch's but may require a small Spacer depending on how flush you want them to sit.
