.A.N.T.
Wheel offset and stud pattern... 16v
This is just a quick question, I've done a search and I'm 90% sure these will be ok, possibly need a spacer but we'll see how they go. Just want to be 100% sure before I hand over lots of hard earned for them...
Will a 17x7.5 ET38 with a stud diameter of 114 fit on my little 16valver?
cheers!
16Valves are 4x100 pcd usually with an offset of et 33 to 38
A pcd of 114 is probably japanese
HTH Marc
As long as you get the correct spigot rings for VW centre bore (57.1mm), then the 4x100 holes will line up. You're right though, I'd run some 5mm spacers to push them out a little...
